NI Package Manager (NIPM)
Error when I try to install NI Visa 2024 Q4
This is the error I'm getting. If anyone knows how to fix this let me know.
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125086
Request type: ComplexSolverTransaction (30)
-125086: An error occurred while upgrading from package 'ni-metauninstaller (24.0.0.49255-0+f103)' to 'ni-metauninstaller (24.8.0.49248-0+f96)'.
File: source\nipkg_client\pkgclient\PluginInteraction.cpp
Line number: 271
Additional error information:
-125530: An error occurred while installing the MSI at 'MU\MetaUninstaller.msi'. The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2705.
File: C:\dev\_r\40\src\package_manager\nipkg\source\shared_agents\WinInstall/ErrorHandler/ErrorInfo.h
Line number: 104
(977 Views)
In general when you hit errors like this you should consider enabling MSI logging as documented here: Generating and Locating NI Package Manager Error Logs. This is helpful to see more error details.
The issue that you are hitting might be related to the issue discussed here: Installation error: ni-metauninstaller (22.0.0.49152-0+f0). In the discussion Wes mentioned an issue where some required reserved folders might not be defined, see Re: Installation error: ni-metauninstaller (22.0.0.49152-0+f0).
Scott Richardson
https://testeract.com
(945 Views)
