NI Labs Discussions
cRIO with USB memory stick
I am using a cRIO with a USB memory stick attacked. It is used for circular storage of most recent data files.
Target: cRIO-9048 with Linux.
I have observed that when dismounting and re-mounting the USB-stick, my LabVIEW application can no longer access the USB-stick: I get a "Generic file I/O error" code 6 when attempting to create a new file, also when letting the application run for a long time, retrying to create a file peridically. The error persist also when restarting the application (not reboot).
Thus, it appears that the USB memory is not hot-swapable (despite it is stated in documentation to be hot-swapable)
After a reboot, the application can access the USB memory again.
Is this expected behaviour of the cRIO?   (from the documentation i would understand the answer to be "NO")
Is there any method to trigger a "re-mapping" of the USB-memory device at run-time?
Message 1 of 1
(3,088 Views)
