NI Labs Discussions
Xilinx Compile Error (Labview FPGA)
I developed a MP3 decoder application and tried to run on the NI PXIe 7965R board. The problem is that before connecting to Xilinx compile server I am stucking at intermediate stage only, the system is running out of memory (I am having 2.5GB RAM System). I thought it may be because of large application, so I reduced some blocks of my applications and tried to run again this time the intermediate stage is successfully completed and connected to Xilinx compile server but now the compile server is out of memory(System memory not board), I attached the error report below. Because as the 2.5GBsystem is out memory can I think that it will not be able to fit on the board, or is it common for applications that may fit on board but requires more powerful system to run?
Thank you,
Chandrasekhar R Patlolla.
(9,923 Views)
I think this question would be better served in the standard discussion forums rather than NILabs. http://forums.ni.com/ni/
Additionally, I am personally interested in the outcome of this can you also email me directly rick.kuhlman@ni.com
Rick Kuhlman
LabVIEW FPGA Product Manager
(3,683 Views)
For anyone who falls upon this thread with similar Out Of Memory failures when compiling under 32-bit Windows, there is an article on Xilinx's support pages that describes a method for providing the Xilinx Compiler with more RAM: http://www.xilinx.com/support/answers/14932.htm
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,683 Views)
