NI Labs Discussions
NI LabVIEW Modbus API Discussion
Hi
I am using the modbus library 1.1.5.39, to communicate with a sensor using Modbus RTU over serial line. The problem is my VI works fine and the EXE works fine too, when run on a pc with LabVIEW installed on it (LV 2013). When I run the exe on a PC with no LabVIEW (lets call it pilot PC) installed, I get an error 56. I tried it as an installer also and included the NI runtime and NI Visa runtime, but still did not work.
Do we need any additional runtime libraries to use it as an EXE.
Thanks in anticipation
Regards
Suvansh
Message 301 of 529
(1,803 Views)
No special runtime needed. Since this is a different computer are you sure the visa resource is the same as what's stored on the exe?
Message 302 of 529
(1,803 Views)
Yep, it was a visa resource problem. All sorted now, works fine
Thanks.
Message 303 of 529
(1,803 Views)
Hi Smithd, Hi everybody
I've used this API successfully to create a RTU Master, IP Master or IP Master with a gateway, RTU over TCP... and my new goal is to add new Modbus functions.
I have to add functions that are not in the Modbus Master API master, for example 18, 21, 22... I know how to write the code for the function. But the problem is that the Master class is protected. So I can’t add to the API
How to do ?
Many thanks
Luc
Luc Desruelle | Mon profil | Mon blog LabVIEW |
LabVIEW Architect (CLA) & TestStand Developper (CTD) | LabVIEW Champion
MESULOG | NERYS
Message 304 of 529
(1,803 Views)
You would want to create a child class of the "master api" class. This (inc an example) is described here:
https://decibel.ni.com/content/message/58374#58374
If have trouble the template I can send another example I made for someone communicating with a specific device.
Message 305 of 529
(1,803 Views)
I'm using this to control a modbus RTU device, it's been working fine for a while but has started giving error:
-1073807298
Property Node (arg 1) in SubVIs.lvlib:RTU Data Unit.lvclass:Read ADU Packet.vi:50300001 -> Modbus Master.lvclass:Write Single Holding Register.vi:24700001 -> Modbus Module.vi -> RT Top Level.vi
Any ideas on possible causes?
Message 306 of 529
(1,803 Views)
Hi what I am doing is to make The MOBUS API working with ARM processor cortex M3,is it possible?
Message 307 of 529
(1,803 Views)
I'm not sure what you mean here. Do you want to communicate with an arm processor? Do you want to run labview and this library on the m3?
Message 308 of 529
(1,803 Views)
-1073807298
There are some KBs on this error on our website but they don't make a ton of sense. This might be the situation if you have a usb to serial converter: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Error-1073807298-on-VISA-write/td-p/193177
The only two property nodes I have in there are reading baud rate and reading bytes at port, neither of which should cause an issue related to the buffer.
When does this error start happening? Does it happen ever time now, or will it work for a few minutes and then fail?
Message 309 of 529
(1,803 Views)
Thanks for the reply,what I am meaning is I want to run labview and MODBUS API on the M3.is it possible?
Message 310 of 529
(1,802 Views)
