NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
PCI6143 digtal output and start trigger running together
Hello every ,I use PCI6143 8 line output to contral the switch, it works well.But when  starting the program with the trigger PFI0  ,there is no high voltage out .and program error“200452” .Trigger source 5V connect to the PFI0.See the picture below for details
大家好,我使用PCI6143 8根线输出来控制开关,效果很好。但是当使用触发PFI0启动程序时,没有高压输出。并且程序错误。触发源5V连接到PFI0。如图 下面的详细信息
请问在PCI6143中无法同时使用8根线输出和触发吗?
如果可以同时使用的话  触发需要配置通道吗 还是直接选PFI0就可以?
0 项奖励
1 条消息(共 2 条)
1,852 次查看
Looks like you are trying to use an argument not supported on this device.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MPKSA2&l=en-US
Are you trying to implement re-triggered generation?
May you please share your vi instead?
0 项奖励
2 条消息(共 2 条)
1,639 次查看
