NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
After ungrade to LabVIEW 2012 from 2011, the execution time doubled on XP OS
Symptom: After upgrade the source code to LabVIEW 2012, the execution time is 300s while previous is 150s with LabVIEW 2011.
Debug:
a. Move .exe to Win 7 OS, the symptom disappeared;
b. Move .exe back to Win XP OS, and remove commands(in script refer to below image) which will produce large amount of response that exceed 160k, the symptom disappeared;
c. Keep all the same, but change area to English from Simple Chinese on XP OS, the symptom disappeared;
Question:
From website http://www.ni.com/labview/os-support/zhs/  we know that LabVIEW 2012 support Win XP, so why has such difference between different languages?
pls advice.
Eli @pegatron
"I think therefore I am"
0 项奖励
1 条消息(共 3 条)
5,826 次查看
Could be just some thing wrong on your Chinese XP.
Try on more pc.
George Zou
0 项奖励
2 条消息(共 3 条)
5,793 次查看
I had tried more than 5 PCs with XP SP3 OS last week, all have the same result, unless change the language to English on XP or move on Win 7 OS;
0 项奖励
3 条消息(共 3 条)
5,790 次查看
