NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
[请教]串口问题
程序我已经粘贴上来了
请参考一下
谢谢
0 项奖励
11 条消息(共 14 条)
2,567 次查看
try the sample. if it isn't OK also. Please re-install driver.
and you said your device's front panel isn't any respone. be focal attention to the command. is it right ?!
detect the VISA OK or not. isn't from the hight light "error field wire info"
 just your instrument's response !
________________________________________________________
Try to make everything Automatic
0 项奖励
12 条消息(共 14 条)
2,565 次查看
0 项奖励
13 条消息(共 14 条)
2,564 次查看
(缓冲区还没有28个数据,所以读出错)试一下,这个,应该没问题了!
︱田︱田田|
Mail:shouwangzhezz@163.com
0 项奖励
14 条消息(共 14 条)
2,555 次查看
