NI FlexRIO Network
Transferring Data from FPGA to Host
Hi ,
I have problem with Flexrio. I get signal parts that do not exist normally. Here is a picture.
(4,903 Views)
Hello!
If you are using a custom adapter module that you have created, I would suggest posting your question in the FlexRIO MDK Community Group.
If you are asking a question about a NI FlexRIO Adapter module, I would suggest creating a service request at ni.com/support and one of the Applications Engineers will be able to help address you questions. When you work with support, the following additional information will help them aid you much quicker.
  • Which FlexRIO are you using?
  • Which Adapter Module are you using?
  • What are you trying to accomplish with your hardware?
  • Have you tried using one of the shipping examples for your adapter module that can be found in the Example Finder within LabVIEW?
Thanks!
Ben Sisney
FlexRIO V&V Engineer
(4,002 Views)
