NI FlexRIO Network
Chassis ground on adapter module?
I plan to use the NI VHDCI cable, P/N SHC68-C68-D4, to connect my custom adapter module to the receiving end. I will be driving LVTTL signals. Therefore I need to ground the cable's shield on my end somehow. My guru says I should ground the shield to chassis ground, *not* signal ground.
Is the mounting hardware electrically connected to earth ground?
If not, how else can I accomplish my goal of separately grounding the cable shield?
(6,677 Views)
The FlexRIO IO Module enclosure is connected to the PXI Chassis ground via the mounting screws.  If you are designing a custom IO Module you can connect signals/planes on your PCB to the IO Module enclosure via the IO Module PCB mounting screws and/or the IO Module front panel.
We are currently working on adding information about chassis/shield ground connections to the MDK manual.
(3,605 Views)
