NI Circuit Design Community Discussions
Nuclear pulse generator
i'm using Multisim  v.10, want to do a simulation for readout electronic for nuclear detector.
First, i need a function generator (refer attachment)  as input pulse for my readout electronic. The pulse is like a Negative Ramp, start at 0V & the amplitude is adjustable up to 1V
Thanks.
(7,645 Views)
Accepted by topic author lojius
The easiest way to do this is with a piecewise liner source (SOURCES > SIGNAL_VOLAGE_SOURCE > PIECEWISE_LINEAR_VOLTAGE). You can construct the sawtooth behaviour by entering data points, and repeating the signal. See the image below for how you should configure the source.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(5,316 Views)
