In this document, the Multisim (LabVIEW based) instruments used for power applications are presented.
Each instruments is demonstrated along with an example circuit.
Download this instrument that takes various single phase poqwer quality measurements on an input voltage and current of a signal, such as:
Example Circuit (drag and drop snippet png file into Multisim):
Download this instrument that allows the user to adjust the load and view the corresponding voltage and current. With this instrument, you cancustomize a pattern for the load value and see in simulation how the voltage accross and the current through react to these changes.
Example circuit:
When you download the instruments (the LLB's), you need to copy them to the User LabVIEW instruments path. On Windows 7, the default User LabVIEW instruments path is:
C:\Users\Public\Documents\National Instruments\Circuit Design Suite 12.0\LVInstruments
If Multisim is already running, you will need to restart Multisim before you can use the instruments.
One final tip, Multisim can also tell you this folder.
