NI Circuit Design Community Discussions
Hello!
Hi my name is Geoff and I am a student doing an indepent study over the summer taking labview and I have a few problems that I am needing some help with. I am in chapter 3 of the 2009 edition and I am trying to turn 8 Leds into a binary(base 2)
representation for a number in a slider. I have the slider as an u8 wired to a fixed point then to( number to boolean) but I am lost as to how to go from the boolean to the leds I have attached a picture of my block diagram.
any help is appreciated.
Geoff
(7,785 Views)
Hi Geoff,
You might have a little better luck posting this question in the LabVIEW board.
I took a quick shot at what I think you might be trying to do.
If  your slide values are only 1 to 8, and you don't want your LEDs in an array you can use your slider as an input to a case select structure.  Then just put each LED in a case corresponding to the slider input.  It's a little more programming work.  But it will be easy to see how it works.
Patrick Allen: FunctionalityUnlimited.ca
(6,653 Views)
Thanks Pallen!
I will post them on the Labview board
Geoff
(6,655 Views)
