NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
niRFSA vs PXI5610
Dear all,
I have PXI-5610 upconverter card. And I want to get the taskID of PXI5610 with the niRFSA library.
How can I do?
And the Downconverter PXI-5600 with the niTuner library which can directly control it, what is the library for PXI-5610?
I found nitnr2u.dll in my system32, but there is no document in ni.com.
regards.
0 積分
1 條訊息(共 2 條)
4,367 檢視
Hi Marspop,
You may take a look at the pdf file named "RFSA Getting Started" for some examples. If you are using C, the help file have C function reference inside.
cheers,
Ko-Wei
下載全部
0 積分
2 條訊息(共 2 條)
4,356 檢視
