NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
鮑率
如何設定150K的鮑率?
0 積分
1 條訊息(共 6 條)
6,629 檢視
Plz see picture attatched.
0 積分
2 條訊息(共 6 條)
6,627 檢視
I am sorry. I use programming is Visual C++6.0, isn't LabView.
0 積分
3 條訊息(共 6 條)
6,625 檢視
I do not know mean of this document. <- About setting baudrate?
0 積分
5 條訊息(共 6 條)
6,611 檢視
The meaning of these documents are below.
Plz contact NI Taiwan to buy NI Serial board to meet your need.
http://digital.ni.com/public.nsf/allkb/95FCD034650CBFAA86256642005BE291
For example, the built in serial ports on most computers have the windows serial driver that can only accept the standard baud rates: 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 28800, 38400, 56000, 57600, 115200, 128000, 256000 bits per second. This means that the VI_ATTR_ASRL_BAUD function will only accept the above values if using those boards.
If you use boards like the NI-843x which driver allows you to use non-standard rates, then you can use this function with ANY baud rate.
Plz contact NI Taiwan for more infomation = TEL : 02-2377-2222
0 積分
6 條訊息(共 6 條)
6,608 檢視
