NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
表示器の点滅方法
お世話になります。
LabVIEWにてLEDなどの表示器を点滅表示させたいのですが、
どのようにすればいいでしょうか?
ご教示お願いいたします。
0 積分
1 條訊息(共 3 條)
6,605 檢視
Hi HTin,
Could you please describe your question in English?
Thanks a lot lo~
hahaha ^____^
0 積分
2 條訊息(共 3 條)
6,591 檢視
Hi HTin
If I understand you correctly, you would like to know how to light a LED (boolean) indicator.
This can be done simply by clicking the indicator or sending a boolean signal to the indicator and
controling it.
Also, could you post in English or Traditional Chinese next time. If you can only key in Japanese,
you might visit NI Japanese forum. (see the bottom of the page linked below)
http://forums.ni.com/
Ryan
0 積分
3 條訊息(共 3 條)
6,520 檢視
