09-12-2011 04:20 AM
I need an equivalent IC for CD74HC75, which is a dual 2-bit transparent latch IC, for a project simulation. Cant find it in the Multisim reference guide.
Any suggestions??
Solved! Go to Solution.
09-12-2011 08:05 AM
emind,
Hello, in the Multisim Analog Devices Evaluation Edition, you will find a D_Latch under the TIL family of parts (use 2 with EN tied together for a dual latch) that you can use for generic simulation purposes. If you need a specific latch from a manufacturer or specific logic family that might be challenging (we have a few in the PRO version or you can add some external circuitry to the TIL part to mimic the behavior of a particular logic family).
The TIL parts (generic digital I/O) are located here: Misc Digital (group) -> TIL -> D_LATCH.
I created a simple interactive circuit with a probe so you can observe the behavior to see if it will meet your simulation needs.
Pat Noonan
09-12-2011 09:51 AM
Thank you sir... but again I am using multisim 10... can you repost the interactive circuit with multisim 10 components?
09-12-2011 10:03 AM
The circuit I built in Multisim ADI edition v11 has some interactive digital I/O parts that are not part of v10. Here is a screen shot of what I created, so you can duplicate it in v10.
For Multisim ADI edition v10 you can replace the interactive digital I/O parts with static voltage sources or with an interactive SPDT switch with logic high (5V) and gnd for the 2 sources to switch between... (BASIC -> SWITCH -> SPDT).
The probe is found under: Indicators -> PROBE
Pat Noonan
09-12-2011 12:48 PM
Thanks a lot, Sir. My project is working now!
