Multisim and Ultiboard
water level indicator 7 segment display and LED problem
hello everyone,i have face a problem which is when i no connect the wire together,the 7-segment displays also show me '4'
after i connect the 1st wire ,the 7 segment displays also show '4'. What is the problem?
In addition,the LED also dont work well, I want my LED 1 light up, when the wire 1 connect, and wire 2 connected,the LED 2 will light up. However now the 3 LED also light up
Thank you so much !
(5,668 Views)
Hello. I love your schematic, it is great.
but lets get serios -
a few problems -
transistors - you connected them all wrong way - collector and emitter should be swopted
resistors R11,12,13 - are to big - let say LED's  direct current is 10 mA, voltage across LED is 2.0 v, and transistor's Vceo is close to 0, so resistance should be (5-2)\0.01 = 300 Ohm
resistors R14.15.16  - there is no need for them actually,
resistors R17.18.19 should be much higher - arounf 2..10 k
fix all that and try again
good luck
Michael
(5,655 Views)
hi,Michael
my 7 segment displays still can not function as well
and my LED is some problem again.When my level 1 connected,my led 1 is off,another 2 is ON.
May i ask you why the voltage go through the Led is 2V?
thanks again!
(5,644 Views)
Again, this forum is NOT dedicated to solve circuit design problems.
However, it is very normal that there is a voltage drop across a LED of approx. 2V. There is current flowing through the LED and the output power (converted to light) must have an origin, so there must be a voltage difference between the two terminals of a LED. The approx. 2V are due to the properties of the internal junction of a LED.
(5,633 Views)
look, in order to answer you I have to understand what task you are trying to acomlosh, and I do not.
please describe how that module shuld work.
 In the meantime I do not understand, why you connected U1-11 to the GRND constantly.
I 'd recomend  - when you are getting  description of what that module should do, build to your selt true table of all input and output conditions .
it 'll make  much easier to build and to troubleshoot.
2 V it is avarage direct drop voltage for most LEDs. that number is good for draft calculations.
exact voltage could be found in specific LED data .
thanks
Michael
(5,619 Views)
Sorry,may i know what forum can i ask this kind of question?thanks
(5,469 Views)
Thank you!
now i trying connect to breadboard
(5,468 Views)
