Multisim and Ultiboard
voltage regulator for battery charger
I have a couple of questions. Im trying to make a battery charging circuit. Im currently using US standard 120V ac 60Hz as input for this circuit. For some reason after I rectify the circuit the frequency is jumping to 120. I believe its because both cycles are being rectified. I wont to bring it back to 60Hz without losing RMS. Also I want to place a voltage regulator that turns off when a 12V voltage is reached in the battery. i am having problems setting this up.
(4,156 Views)
Hi. I am currently doing a circuit with cut off. If you don't mind, can you explain a little bit about your circuit above with me. i would like to learn to complete my circuit.
thank you
(3,179 Views)
Can you be more specific with what you want to know?
(3,160 Views)
It is basically a buck (step-down) converter. Utilizing an igbt as a switch.
(3,159 Views)
