Multisim and Ultiboard
voltage-frequency
Hi all,
I am trying to build a spice model to become voltage-frequency but I’m having a lot of troubles by using real components.
Does anyone know a virtual component in Multisim able to become voltage-frequency or any other way that I can control the frequency of the clock source?
Thank you very much
Roosvelt
Note: I made a mistake in the previous email
(4,345 Views)
This is just an idea because I have no clue as to what voltage or frequency you are delaing with, but the 555 Timer can be arranged to vary a frequency depending on the voltage applied to Pin Number 5. I believe that the Timer will run at it's designed free-running frequency with no volatage applied and then increase in frequency as this voltage goes up.
I am not sure this is what your after, but it may be a starting point.
Message Edited by lacy on 12-26-2006 04:05 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,342 Views)
thanks Lacy for your support,
The timer 555 is a very good option. Its maximum frequency is around 10Mhz which is fine for my application. also it allow me vary the duty ciclo as astable mode. I just need a device able to vary the frequency and its duty ciclo by external components, so the 555 the best option.
thank you very much.
(4,329 Views)
