01-17-2009 12:50 PM
01-20-2009 01:45 PM
Hi there,
Thank you very much for your feedback. We have identified this problem and are looking into a fix for this right now. In the mean time, I have created a heirarchical block (var_cap.ms10) which can be used to replace this component. The multiplier block along with the capacitor implements the d(CV)/dt functionality. You can use the heirarchical block in your schematic by using the Heirarchical Block from File item from your Place menu. A simple test bench is also attached to demonstrate the functionality.
Hope that helps. If you need any more assistance, please let us know.
06-07-2013 02:55 AM
I wonder where the distortion (see file attached) is coming from ? Is this as it is supposed to be ?
