I want to copy an existing pc board layout into a new project. The new project's board outline has mounting holes of the same size and in the same locations as the existing project, but the new board is larger. Using one of the mounting holes as a reference point, I'd like to paste the existing layout into the new project. Need some help with this please.
I am using Ultiboard V10.0.144.
已解决! 转到解答。
Hi Joe,
Make sure all your selection filter are enabled, have a look at this link if you are not sure what I am talking about: http://www.ni.com/white-paper/13271/en. To copy one design to another, simply press Ctrl+A then Ctrl+C. In the new design, select Ctrl+V or Edit>>paste with net if you want to import the nets from the old design.
Have a look at this move multi object KB, it may be useful.
http://digital.ni.com/public.nsf/allkb/5AB46D3D8B5461EA86257AFB005C3116
Yep, simple copy and paste with nets worked great. Being new to the program, I didn't know how to unlock locked objects but I figured this out too. Thanks very much!
