Multisim and Ultiboard
to display from number 0 to 167
This is first time posting in this group... i'm trying to to display 0 to 167 using counter (JK flip flop) ..... however i'm using gate only not set prepared by the multisim
i'm having problem displaying after 9 where the digit went up by 10 instead of 1 ( 9,10,11,21,31,41,51,61,....91,12,22,32,42)
anyone can help??
(5,257 Views)
Hi there,
In Multisim, we can group the gates as a whole "JK flip flop function block" using the "hierarchical block" to simplify the circuit. All you need to do is select the gates and wires respectively and right click, there is an item called "Replace by hierarchical block  Ctrl+Shift+H". Then name the block and place it.
Hope this helps,
Chen_T
(5,201 Views)
