Multisim and Ultiboard
simulation of same circuit design in different multisim versions give different results
multisim version 10.0 , PATTERN16T GIVES RESULTS ON... DISPLAYSA2A20000A2A20000AAAA0000AAAA0000.....
MULTISIM VERISION 10.1, PATTERN16T GIVES RESULTS ON
DISPLAYS A3A30000A3A30000A3A30000.......
EACH MULTISIM PROGRAM USE THE SAME CIRCUIT FOR ANALASIS.
MULTISIM 10.0 VERSION GIVES THE CORRECT RESULT.
YOU MAY HAVE TO CHECK THE NEW VERSION FOR THIS PROBLEM
WITH MULTISIM 10.0 VERSION.
RICHARD RUHL
Message 1 of 11
(6,885 Views)
Accepted by topic author ruhl
Could you please attach your circuit(s) for further troubleshooting? What's your operating system?
Fernando D.
Message 2 of 11
(6,845 Views)
operating system is winows xp.  Iam sending you this file pattern16t.
Message 3 of 11
(6,821 Views)
my operating system is windows xp. sending you pattern16t. might have to send you the file over my email. said loaded with errors.
Message 4 of 11
(6,817 Views)
Just zip the file and attach it here. Just to confirm, you are using Multisim 10.0 and 10.1?
Fernando D.
Message 5 of 11
(6,814 Views)
yes I am using multisim 10.0 and mulisim 10.1
Message 6 of 11
(6,795 Views)
sending you a change in pattern16t schematic.  A2 comes up everytime in multisim 10.0 but in Multisim 10.1 the disply stays zero with same schematic.
Message 7 of 11
(6,770 Views)
the cap connected to the clk is now 150p in value.
Message 8 of 11
(6,744 Views)
clk cap s now 1000pF and xral is now 5MHZ. any results.
Message 9 of 11
(6,706 Views)
problem solved-made new ckt. model of 74LS244N.  Both versions work with same ckt.
Fan in and Fan out doesn't show indication when to many gate inputs are tied to one output.
gate output max current 16ma.
gate inpts draws max current 1.6ma
number of inputs should add up to about half of gare output max current 16ma
attaching final pattern16T schematic with all the corrections.
Message 10 of 11
(6,630 Views)
