Multisim and Ultiboard
sensor input to NI multisim
Is it possible to take sensor ouputs (IR sensor - L14F1 and UV sensor- TW30SX) to virtual environment in Multisim using myDAQ?
(5,323 Views)
There is two options I can think of for doing that. At the moment, you can read the values (using the myDAQ instruments) but you are not able to drag these values to use within a simulation. If you are well versed in LabVIEW, you can use it to get these readings and then pass them in Multisim through Co-simulation, OR create a vritual instrument (once again using LabVIEW) to get the outputs within your cricuit. Otherwise, there is no way Multisim can natively get those readings to use in simulation.
Kind regards,
Miguel V
(5,293 Views)
