Multisim and Ultiboard
numeric overflow in device model in Multisim 13
I'm trying to get frequency responce from 1 to 20000 Hz at Probe1 an I get this error, please help.
(7,521 Views)
Accepted by topic author Jehanamu
Hi there,
I've checked your circuit, there are two things need to be modified.
First of all, you connected the negative 9V to the positive VS+ of your op-am which can burn the device in real life.
Secondly, for your output terminal, you grounded the probe1 directly, which means there will be no output signal at all. You can add a junction(ctrl + J)  next to your R5 and delete the wire to the ground to fix it.
The frequency response from 1 to 20kHz is shown below.
Attached is the fixed circuit.
Chen_T
(7,504 Views)
Thank you very much for help
(7,497 Views)
