Multisim and Ultiboard
numeric keyboard
Hi all,
I have to simulate an alarm system, and I have to insert a specific 4 characters code to activate the alarm system. I want the code to be entered throughout the dtmf_keypad on the screen, but i can't understand how this component works. Can anyone help me please?
Message Edited by vaito84 on 11-10-2009 12:14 PM
(11,368 Views)
basically the kepyad is a 4x4 matrix, each row represents a low frequency, and each columns a high frequency. Double-click the keypad, go to the 'Display' tab, uncheck 'Use schematic Global Setting', check 'Show Symbols Pin Names'; you will see more details.
The input to the keypad can be done either by using your keyboard or the mouse.
You can find an example in Multisim on how to use keypads. Go to File>>Open Samples>>MCU Sample Circuits>>805x Samples and open the file 'Calculator.ms10'.
I hope this helps.
Bye!
Licia
(11,347 Views)
A good help from you, Licia, thanks!
if i need something else, i'll write in the italian section Smiley Happy
Ciao
Vito
(11,344 Views)
Will I need to programme The 8051 IC ?
(8,330 Views)
