Multisim and Ultiboard
multisim user error user.ewfg not found
Hello ! I have a problem with Multisim 8: i've installed it as administrator and when i try to launch it as a user (the user name is student) i get this error: student.ewfg not found default.ewfg nor found! i have enabled Full control options and it still doesn't work. It would be great if anyone can help me. Thank you
(4,075 Views)
If you logged on the machine with an ‘admin” account Multisim starts but when logged on with a "user" account, it does not, then this have to be a permission issue.  You need to give everyone full access to the following folders:
1.  Multisim user
2.  Database
Double check mscomp_s.prd inside the database folder, the permission you set on the Database folder does not inherent to this file.
Tien P.
(4,058 Views)
