Multisim and Ultiboard
layer stack-up report empty?
This may be a bug.   My UB export layer stack-up report is empty except for a header and sometime almost a few characters of some layer names.
This is what I get:
Ultiboard Information Export File
Design Name  : Power Dist Board-1082-0_01 - Layer stack-up
Report Date  : 29 March 2016
Report Time  : 18:25
That's the full file content.
UB14.0.1, Win10 64b
(5,442 Views)
Can you describe the process that you are following to create the stack-up report? Is this happening with other files?
Randy @Rscd27@
(5,425 Views)
Just click on export and select the layer stackup report check box, text option.  I also check for gerbers, dxf and various other reports as well.
This is a 6 layer design, with the standard silkscreen and solder/paste masks.
The board statistics text report looks fine.
Here is another try in which part of some layer info made it into the report, then no more:
Report Date  : 21 March 2016
Report Time  : 14:00
Copper Top
Signal
T
(5,417 Views)
Hello dbur,
I use one of the examples that is shipped with NI-Ultiboard named Iint4lRouted.ewprj, the examples are usually located in C:\Users\Public\Documents\National Instruments\Circuit Design Suite 14.0\samples
Remember to open the file directly from Ultiboard.
This is a simple design with Copper Top, 2 inner layers and Copper Bottom.
I proceed to generate the report in a .txt file
Then I reviewed the exported file:
And it seems to be correct. Based on the Ultiboard User-Manual:
http://www.ni.com/pdf/manuals/374488a.pdf (Check Page 8-16)
It seems that is showing the correct information. I believe that you must try this example and verify if the report is generated correctly. If you can generated correctly it could mean that there is a corruption of your project or a bug. Can you attach your project to test it?
Warm Regards,
Randy
Applications Engineering
www.ni.com/support
Randy @Rscd27@
(5,406 Views)
Yes I got that result on the sample file.  I cannot post my file here because it is customer proprietary.
I tried a much earlier version and it had the same problem.
I tried several entirely different old designs and they also had the same problem.
I tried a design file from someone else and it did work.
OK, I think I found the issue.  The report does not generate correctly if you don't have all the layers hard selected first in the design toolbox.
I believe this should be an error.  The layers exist and should be properly reported, whether they are enabled in the Design Toolbox for viewing or not.
(5,394 Views)
I am glad that now is working. Please post that request in the idea exchange forum and request that feature for next Multisim versions. The R&D department usually monitore this forum:
http://forums.ni.com/t5/Multisim-and-Ultiboard-Idea/idb-p/multisimideas
If you have more questions let us know.
Warm Regards,
Randy
www.ni.com/support
Randy @Rscd27@
(5,386 Views)
