07-02-2009 04:14 AM - edited 07-02-2009 04:18 AM
I draw in multisim 10.0 just for layout purpose, no simulation is needed.
Now I want to work in parts / groups.
I'll include an image that will explain what I want:
Now I've used netlabels, but I want something like this:
It's about the RX / TX with the bubble.
I'm unable to quickly place a virtual pin, a pin that won't show in ultiboard to connect my pic with the header.
Solved! Go to Solution.
07-02-2009 10:30 AM
07-03-2009 01:33 AM
Thanks, that's interesting, but you've manually changed each label?
I was hoping that the netname was used for the label, so it would automatic change it's name when the netname changed.
There is a function label in multisim, but it changed the netname of the wire.
(CTRL + I) or (Place --> Connectors --> HB / SC Connector)
I would like that the label use the name of the connected net (wire).
07-06-2009 01:24 AM - edited 07-06-2009 01:34 AM
I found a topic in the FAQ:
http://digital.ni.com/public.nsf/allkb/7D1350E5A9935EE4862572050054DDC2
But it's for multisim 9 (10.0 cannot follow these steps given in the FAQ).
@ morgol, thanks, I've used your symbol.
I wanted an automatic system (label use the name of the net, but this working for the moment).
07-06-2009 08:41 AM
Looking at that FAQ you referenced, in the bottom paragraph it looks like it is describing what I did in my example.
National Instruments wrote:...The method to connect one component to another without a wire is the same as described in the manual. Double-click on a wire and rename the node so that it matches...
As far as I know (and I am fairly confident that I am correct) there is no defined system of making the net names drive any component names in Multisim. In general Multisim treats net names as insignificant in terms of preserving their names (especially custom ones).
