Multisim and Ultiboard
how to get rid of component names and add resistor values
I am just getting started with  the student edition of Multisim. Firstly, when I place a component such as a jack, there is a large title with the compontent that gets it the way of the schematic. How do I remove it? Second, it seems that there is only 1 resistor value, 82K, in this edition. Do I have to make a new component for each value? If so, how is it done? Thanks for the help!
(7,706 Views)
bump!
(7,686 Views)
1. When you place a component on the work area, you can double click on it and select the "Display" tab, uncheck the "Use schematic global setting" and you have the option to turn on/off various component label.
2. Multisim have a lot of resistors, go to the "basic" group and select the "resistor" family, you should see many resistor values. Directly below "Component" there is a filter, if you type "8" Multisim will filter out other values and only 8 appears in the list, place your mouse pointer in the filter and press the backspace button on your keyboard to clear the 82K and Multisim will show you the complete list. I prefer to drop any resistor on the work area and use the copy/paste function, when I double click on the resistor, I can change the value.
Tien P.
(7,683 Views)
Thanks. I will give it a try.
(7,680 Views)
