Multisim and Ultiboard
how to connect from adc to dac
Hello everyone!
I need some help from you, I am using multisim simulation 10.0 to convert ADC to DAC.  Do you have any example for about this, i am confusing how to connect it to each other and measure the output voltage. Here is my circuit, can you take a look and give any comment.  Thank you.
Message 1 of 10
(8,681 Views)
It doesn't look like your circuit was attached successfully.
____
Ryan R.
R&D
Message 2 of 10
(8,674 Views)
Oh i'm sorry.  This is the picture of my circuit.  Thank you for your help.
Message 3 of 10
(8,664 Views)
Did you know you can attach the actual circuit file? That would work a lot better since I can't really make out that picture well enough to troubleshoot, and nobody wants to build it from the picture themselves. 🙂
____
Ryan R.
R&D
Message 4 of 10
(8,650 Views)
Message 5 of 10
(8,646 Views)
Thank you for your comment, i tried to upload it last night but somehow they won't let me.  But now it's work, can you show me how to connect it.  I really need to solve this problem.  Thank you so much.
Message 6 of 10
(8,641 Views)
This is my update circuit can you look over it and give me your commnet.
Message 7 of 10
(8,638 Views)
Hi Phu_Fu,
When you a place a component on the work area and it's green, it's an indication that the component does not have a model and will not simulate.  Components without models came from the Multicap database which is a schematic capture only package and they were put in Multisim anyway just in case someone doesn’t care about simulation and want to use them.
In Multisim there is a generic ADC and DAC component with model, you can find these components in the same family where you got the DAC8541.  I made a sample circuit with these components and it's attached.
Tien P.
Message 8 of 10
(8,632 Views)
Something to remember:
Black = Model Only
Green = Footprint Only
Blue = Model and Footprint
____
Ryan R.
R&D
Message 9 of 10
(8,612 Views)
Thank anh Tien and Ryan for your help.  I am working on this circuit and test it over again.  If i have any trouble shooting i will post my question again, your suggestion are help me a lot.
Message 10 of 10
(8,609 Views)
