Hi, friends.
I have problems with DC Sweep while simulating logic elements transition with Multisim 12.
The circuit is the next:
at Simulate / Digital Simulate settings : Ideal
I have for CD4011
for 7400
Not understandable output voltage range [ 0 V, 1 V ]
Quite acceptable for “Ideal” input voltage for transition = VCC / 2
at Simulate / Digital Simulate settings : Real
I have for CD4011
for 7400
Quite acceptable transition input voltage for 4011 transition as CMOS.
Strange curve shape for 7404. But voltage range [ 0.8 V, 1.6 V ] agree with standard TTL transition input voltage.
I have not find resolution in Multisim manuals and in Multisim control.
I hoped that corresponding information contains in IC definitions, but have not found it there:
4011
.MODEL 4011IC d_chip ( behaviour= "
+; 4011IC Quad 2-input NAND gate
+/inputs 1A 1B 2A 2B 3A 3B 4A 4B
+/outputs 1Y 2Y 3Y 4Y
+/module NAND00
+/inputs A B
+/outputs Y
+/table 4
+; A B Y
+ L L H
+ L H H
+ H L H
+ H H L
+/delay 2
+; input output Rise time Fall time
+ A Y 110n 110n
+ B Y 110n 110n
+/endmodule
+/instance NAND00 1A 1B 1Y
+/instance NAND00 2A 2B 2Y
+/instance NAND00 3A 3B 3Y
+/instance NAND00 4A 4B 4Y
7400
a%p_a [%t1A?%t:d%t;1A %t1B?%t:d%t;1B] %t1Y?%t:d%t;1Y %m
So, i would be very thankful for any help.
Regards.
yg
