Multisim and Ultiboard
error with opa4228?
I'm trying to build a second order low pass filter using OPA4228 and when I run the AC Analysis of the filter I keep getting the results that I should get if I had built an high pass.
In fact, if I exchange the OPA4228 with another opamp (NE5532 for example) the results of the AC Analysis are correct, so I'm sure that my circuit is well made.I get this error even with OPA228.
Can anyone help me fix this problem, please? (My circuit project is in attachment)
(4,198 Views)
Accepted by topic author coconuttree
This has to do with the voltage that you are passing through your component. I changed it to a reasonable amount (I don't know the actual limit, you can look that up in the data sheet) and fixed your power sources (They were backwards), and it seems to drive it properly now.
Cheers,
Miguel V
(4,171 Views)
