Multisim and Ultiboard
drill files sizes of holes
The PCB house I use want to know the size of holes and the number of different sizes of holes in a design for the price quote. Ultiboard 2001 produces a file, XXX Drill info.rep when you export the NC drill files. You can use a text editor to look at the information. Ultiboard 10.0.267 does not seem to produce this file when you export the NC drill files. Is this correct?
dlh98370
(3,345 Views)
I can't speak for 10.0.267, but 10.0.343 (the latest version) produces the drill info.rep file. When you export the NC Drill files you must make sure you export both files.
Once the first file, which is the .DRL, is saved it automatically queries you to save the second file which is the .REP file. It may be that you are interupting the process and not saving the second file. If this is not the case, then it may be possible that you need to update your version to the latest which is 10.0.343.
I hope this helps.
Message Edited by lacy on 03-10-2008 09:33 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,342 Views)
