Multisim and Ultiboard
distinguishing when to use off-page vs global connector
New to Multi-sim -
Is there a tutorial for the intended purpose of using off-page connectors and not global?
1.  Suppose nets need to be connected to a number of sheets, should global connectors be used or should off-page connectors of same name be used.  What the intent of the two?
2.  Can global connectors be connected to buses for linking to sheets? or should an off-page connector be connected to a bus?
An explanation should be entered into HELP, and perhaps a tutorial.
(6,000 Views)
Accepted by topic author johnkimura
Hi johnkimura,
In the help file, you can search for connector types and you will find the help documentation about the connectors. The difference between an off page and a global connector is that an off page connector is only visible on the same level in the hierarchy. What this means is that if you are in one sub-circuit, you can use an off page connector to connect to another sub-circuit at the same level.
For Bus lines, you need to use the bus off page connector.
Hope this helps.
Tayyab R,
National Instruments.
(5,974 Views)
