Multisim and Ultiboard
copy library
Hey,
I use multisim 11 full version in my work and on my personal pc I am using multisim 10 studentversion.One component is: ADTL084ARZ as example
It´s possible to copy some components, which are available in the new version to my studentversion ??
I tried to export it, but i get some problems with the format.
I hope someone can help me.
(3,881 Views)
You can save the design, open it on the other computer, and then select the component, then save it to the local user database. (Tools / database / save component to db)
(3,856 Views)
If you are using Multisim Full or Base you do not have the ability to Export or Import from the Database Manager.  However, you still can export and import components by copying the User Database.  The following link explains how to accomplish this task.
How to Import and Export Components in Multisim?
I hope this will help
Best regads,
Houssam
(3,845 Views)
