Multisim and Ultiboard
component in Multisim
Hi guys,
I just started learning in Multisim.  I tried to add a 4011 and 4017 CMOS Gate into my circuit, but I don't know how to connect VDD and GND to the ICs.  Because there are only input and output pins.  I also wonder that if I can enlarge the 4017 itself on my schematic diagram.  I know how to increase the zoom of the entired schematic.  Please advise, thank you.
Harrison
(4,775 Views)
Accepted by topic author Harrison
You don't have to wire up the power on digital IC's. The Power pin are hidden and the only thing you have to do is place VCC,VDD, VSS or DGND on the schematic and the IC's will be automaticlly hooked to them in the background (you won't see any physical connections).
For the second question. The only way I know of to do this is to edit the components symbol in the Symbol Editor. Double click on the component and goto the Value tab and you will se where it sys to "Edit  Component in Database" Click that and it will take you to a new dialog box. Select the tab "SYMBOL" then you will see down below where it say "EDIT" From here you will enter the symbol editor and can edit the component symbol however you like.
I would suggest reading the Multisim Manual about the symbol editor to familiarize yourself on its operation. I don't use it that much and would have to review this myself.
I hope I have helped.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,764 Views)
