Multisim and Ultiboard
circuit parameter
Hello to all,
i am a new user of multisim.
Multisim is simple and functional..... but i have a question.
In pspice you can call the value of a series of device with a parameter.
Changing the value of this parameter, this is set to all device of the series.
So if the circuit is repetitive and you want to make a change to a component repeated n times (for example the resistence of a group of resistor) you can change the value of parameter (for example the value of resistence) and this value will be changed to all components related to the parameter.
you can do the same thing in multisim?
many thanks in advance,
fabio
(5,071 Views)
Hello Fabio,
Thank you for contacting us. One of the new features in Multisim 13 is Circuit Parameters. They can be used to explore diferent scenarios for components and circuits. Please refer to the following tutorial to learn more about this new feature:
Advanced Circuit Analysis and Exploration with Circuit Parameters in NI Multisim
Fernando D.
(5,063 Views)
thank you!
I did upgrade to multisim13 and I managed!
I thought there was also in the previous version but it is not so!
thank you again!
Fabio
(5,038 Views)
