Multisim and Ultiboard
chained op-amp simulation error
Hello. The simulation always halts here. is there something wrong?
(no, the assistant, while pretty good can not solve this issue)
It does work fine with the "virtual opamp" parts.
(2,499 Views)
Did you tried to source the op-amps not from the VDD and VEE but with DC power source (basically the battery)?
__________________________________________
The best way to thank, is to give KUDOS
(2,430 Views)
I did not try that yet, but to me it should make no difference in my mind. I'll give it a try.
(2,411 Views)
VDD and VEE have different properties than power supply.
Also, what warnings or error Multisim shows up at the bottom (in the spreadsheet vew)?
And having ground in the schematic affects as well.
(2,342 Views)
