Multisim and Ultiboard
autorouter
ultiboard10 布线问题
我在用MULTISIM10 画完电路 填完相关元件的封装后
直接到入到ultiboard10里 设置成双面板  并设置低层布线  定层不布线
但是在用自动布线功能的时候
却不能显示低层布线的效果
布完后元件之间依然是飞线相连
另外  可以用手动布线布地层的线  这到底是为什么啊??
(3,616 Views)
Translation
ultiboard10 routing problem
I filled out the circuit using MULTISIM10 unfinished after the relevant components of the package
Into the ultiboard10 directly to the inside and set the low-level panel set up to dual-layer wiring is not fixed wiring
However, when the automatic routing capabilities
Do not show the effect of low-level routing
Cloth exhausted component is still flying between the lines connected
Also you can manually routing fabric formation line which in the end Why
(3,575 Views)
I don't understand the translation and I've read it  5 times.......anyone want to try and convert it to something more understandable than a babelfish translation.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,563 Views)
