Multisim and Ultiboard
ac analysis
Hallo
I would like to save batch analysis, to use it on many other circuits
I need on many curcuits ac analysis in a range of 25Hz 50Hz 75Hz 100Hz and so on.
I wasn't able to find save batch analysi, it just shows me 2 at batch analysis option. I will adding a picture.
Or please tell me please how is the best way to handle this problem
(5,249 Views)
I am not sure - can you open the 'batch analysis' and get the setup window? Which version are you using (v11/12, edu, pro?)
Pat Noonan
(5,213 Views)
I got power pro edition v.11 "look at the picture"
I got a setup at batch analysis "look at the picture"
(5,205 Views)
Dear MultisimUser,
You can save the AC Simulation when you go to "Simulate" and then select "Save simulation settings...":
There you can choose which Simulations you want to save:
So when you want only to save the AC Simulation you can create view different ones and save each of them in a single Simulation File and load this File when you need the simulation.
Kind Regards,
Oleg Scherling, M.Eng | Applications Engineering | National Instruments | NIG |
(5,133 Views)
