Multisim and Ultiboard
What file/registry permissions are required to run MultiSim 7 as a regular user?
I want to be able to run MultiSim 7 as a regular user (since our students obviously do not have administrative permissions/rights).
I can't quite figure out what file and registry permissions are required to be able to do this (despite using Filemon and Regmon).
(4,920 Views)
Look at this knowledgebase: "How do I give a computer user without administrator rights the proper file privilege to run Multisim?"
http://digital.ni.com/public.nsf/allkb/0DF597C217A235BE862571FB004F24BD
It is made for version 9 but it should apply for your version 7 as well. Although, I would recommend giving Full Control privileges to 'everyone' on all the EWB installation folder.
Nestor
(4,915 Views)
If you are refering to the "failed to update registry" warning message, do this:
1.  Click Start-->Run
2.  Type "regedt32"
3.  Locate HKEY_Classes_Root/Multisim.Document
4.  On the menu, select Security-->Permission (win 2000), For  XP select Edit-->Permission
5.  Give full control for everyone
6.  Repeat step 3-->5 for:
HKEY_Classes_Root/CLSID/{2D964073-9BC9-11D1-840B-006008AC6551}
Tien Pham
EWB Support
Tien P.
(4,905 Views)
