Multisim and Ultiboard
Utilboard Title Block
Good day.
I have used Ultiboard 11 & currently using version 12.0.0(12.0.592). In both instances there has not been an option to create a project "Tile Block" as in Multisim . The best Ultiboard has is the " Printer Header Function" before printing . (This would be useful if it could be edited.) Has anybody managed to create a Tile Block in the Ultiboard work area?.
Any advice would be greatly appreciated.
Regards
LucB1
(3,873 Views)
Hi LucB1,
Unfortunately, it is not really possible to insert a title block in Ultiboard like you can in Multisim because of the nature of the softwares. The best way you can add something like that is to create it in a DXF sofware like AutoCAD and then import the DXF into Ultiboard. This kind of information would generally be on the Mechanical Layer. You can still place text, graphics and Bitmap Images in Ultiboard.
Hope this helps.
Tayyab R,
National Instruments.
(3,862 Views)
