Multisim and Ultiboard
Using the grpdelay function.
I have been trying to calculate the group delay thru a filter circuit, 3rd order bessel, with little success.  I've tried to use the expression builder on the output tab of the AC analysis.  The expression I've used is:
    grpdelay(V(4))  where V(4) is the output of circuit.
I know what to expect for the group delay based on two different tools that I can download from the TI website.  But the values that I get don't match up.
Can anyone offer a suggestion?
Greg
(6,310 Views)
I realize this is about 3 months late, but I'm having similar issues.  Maybe someone more familiar with the postprocessor can clarify why the SPICE commands in Multisim (10.0.343) work this way.
The group delay of a circuit is simply the negative derivative of phase wrt frequency: -dphase/dfreq.  According to my SPICE reference book, vg(vout1) will simply perform this derivative for you, and I incorrectly assumed "grpdelay" was NI's re-mapping of this macro.  In order to obtain the correct delay values I need to enter:
180*grpdelay(V(vout1))/pi
or equivalently,
-deriv(vp(V(vout1)))/(2*pi)
Why do we need a conversion factor to get the correct group delay?
-Jason
(6,151 Views)
I'd really appreciate a response from NI regarding this matter.  I've run into another case where I need to calculate the group delay of an analog filter, but the supplied grpdelay() macro does not supply the correct value unless I scale it appropriately.
(5,859 Views)
You have come across a bug.  There is a factor error in the resulting group delay calculation. This problem will be rectified as soon as possible.
 For now, the best way to get the correct result is to do it manually by writing the following expression in the in the post processor (without quotes):
"-deriv(ph(V(out)))/(2*pi)"
where v(out) is the complex vector of interest.
Note that the function ph() returns the phase in radians and hence the 2pi scaler.
Sorry for this inconvenience
Message Edited by MaxNI on 03-16-2009 11:15 AM
Max
(5,820 Views)
Hello!
I'm found this topic few days ago. And I need to calculate group delay. Can you please help me with it?
Expression  -deriv(ph(V(out)))/(2*pi)  still best way to get the correct result?
(672 Views)
The issue is almost certainly your simulation step size. The grpdelay function is extremely sensitive to frequency resolution because it's a derivative. Try increasing your points per decade in the AC sweep to at least 100 or 500. Also you can visit megamedusa-casinoaus to get the best gaming offers. If the phase data is too coarse, the math behind the derivative will fall apart.
(359 Views)
