Multisim and Ultiboard
Ultiboard - Footprint without the wizard
I have a problem I want to create a footprint for an AF transformer R/Z1606
A proper arrangement of the pins with the component wizard is impossible.
Is there an alternative to create footprints without the wizard, or maybe a possibility to arrange the pins as desired ?
http://docs-europe.electrocomponents.com/webdocs/05a8/0900766b805a8d3e.pdf
your sincerely,
Stojan Nikolic
(4,307 Views)
Accepted by topic author Stojan_Nikolic
Hi Stojan,
You can create components without the Wizard - of course, then you have to do everything manually.
  1. Click Tools > Database > Database Manager
  2. In the Database Manager dialog, next to Parts, click the Create new part button (hover your mouse over the items to see the tip)
  3. In the Select the Part to Create dialog, select PCB Part, and click OK
  4. Create your part
  5. When you are done, click File > Save to database as... to save the part you created
For more details, see the complete tutorial on the NI DevZone.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,300 Views)
Thank you!!! I searched 3 hours to find a resolution
(4,297 Views)
