Multisim and Ultiboard
キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Toolbar bugs
Bug #1:  Customizing the file toolbar to add a "close standard" option does not retain the new icon I've added onto the toolbar after re-starting Multi-Sim.  I'm not sure if other toolbar customizations are the same way or not.  I think this is a bug because I haven't seen an option to NOT retain customizations after exiting (that seems to be not the point of customizing the GUI).
Bug #2:  Toolbars don't 'go back' to the position they were in if the window gets resized, or if you're in the options and select large icons, and then de-select it.  Selecting large icons spaces the toolbars at the minimum distance with the bigger icons and then when you de-select then all the icons are back to normal size but the toolbars are spaced out.  Having to rearrange all of the toolbars when something happens to the window or whatnot shouldn't be necessary.
0 件の賞賛
メッセージ1/5
3,920件の閲覧回数
Looks like at least #2 is a known and reported issue already: See #11 on this list
0 件の賞賛
メッセージ2/5
3,907件の閲覧回数
I was not able to replicate bug 1 in Multisim 10.  Is this the same version you are using?
Can you try this procedure again and see if it works, there is a known issue (bug 2) were the toolbar changes occasionally and I was wondering if this is the same thing that is happening to you.
Tien P.
0 件の賞賛
メッセージ3/5
3,881件の閲覧回数
Correction, I was able to replicate the problem. I cannot however provide reproducible steps, it seems to work in one instance and the next time when I followed the same steps it does not work.  I will ask Q&A to look into this problem.
Tien P.
0 件の賞賛
メッセージ4/5
3,878件の閲覧回数
Well since it deletes my icon every time here's the step list to reproduce it.  I am using the latest version of Multisim.
  • Start Multisim
  • Right click menu > Customize
  • At customize dialog, select "Close (Standard)"
  • Drag to fourth icon from left on file toolbar
  • At popup dialog select Image Only
  • Select 4th icon down on left side (close icon)
  • Select Close to dismiss the customize dialog box
  • Restart Multisim
  • Icon is gone
0 件の賞賛
メッセージ5/5
3,864件の閲覧回数
