05-21-2012 06:56 AM
I'm actually in internship and i need simulate an active power filters with this transistor : IRGTIN050M12.
When i run my simualation, there is this error : Timestep too small
I have tried to changed some parameters :
- Under Initial conditions select Set to zeroulation now works.
- Change Maximum Time Step (TMAX) from 1e-005 to 1e-003
- Relative Error Tolerance [RELTOL] to 0.01
- Shunt resistance from analog nodes to ground [RSHUNT] to 1e+9
- Integration Method [METHOD] to Gear
But i have the same error...
If someone can help me.
(I am sorry for my english)
05-22-2012 06:29 AM
Have you try to change the Maximum time step on MultiSim options :
1. Analysis Options>>SPICE Options>>Use Multisim Defaults
2. Analysis Parameters>>Parameters>>Maximum time step (TMAX) = 1e-13 Sec
Generally, you would like to set the TMAX parameter to be significantly less than the smallest feature in your signal.
Let me know if the problem continues.
Best Regards,
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
