Multisim and Ultiboard
Temperature sweep analysis problem
Hello
I am having problem getting even the simplest  temperature sweep analysis to work in multisim 10.
As an example, please see attached circuit and pictures.
The circuit contains a simple voltage divider where R1 has a TC1 of 1 ohm/C, and as shown in figure 1, the resulting voltage is 0.5V when running simulation at
27degree C with TNOM 27C.
Raising the Temperature to 28degree C results in a resulting voltage of 0.33V (figure 2) (indicating  a doubling of the R1 value because of the 1 degree temperature raise with a TC1 of 1ohm/C)
To my understanding, the R1 value should have changed with only 1 ohm.
Any hints on what might be the problem with my temperature analysis ??
Does anybody know if this is a known error with Multisim ??
Any advice/hint is appreciated !
Message 1 of 8
(5,521 Views)
You are correct in you observation. The value is effectively being doubled. This is apparently a software error that will have to be further addressed by NI. I am responding only verify your findings (2 or more people reporting the same results are always better than just one person reporting it).
I have no answer as to how to work around this. NI will have to read this and maybe they can come up with a temprary solution until a permanent one can be found.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
Message 2 of 8
(5,491 Views)
This was reported to R&D (#103149) for further investigation.
Thanks for the feedback!
Øyvind Ø
Message 3 of 8
(5,450 Views)
The problem is with the units label in the resistor dialog box, not with the result. tc1 actually has units [1/degC] and once multiplied by some temperature difference, acts only as a factor.
The formula for resistance is as follows:
R = Rnominal *(1+tc1*(T-Tnom) + tc2*(T-Tnom)^2), where in your case  tc1=1, tc2=0 and Tnom=27 and T=28
therefore R=2*Rnominal
This defect will be registered
Max
Message 4 of 8
(5,431 Views)
Thank's
Using the unit [1/degC] for the TC seems to give results as expected
Åsmund
Message 5 of 8
(5,408 Views)
Asmund, please forgive me for being stupid at the moment, but could you explain how you set this up to get the results you needed as I am still a little fuzzy on this. Thanks for any information you can give.
Have a Nice Day
Message 6 of 8
(5,386 Views)
OK
1 Ohm/degC at 5kohm nominal value is 1/5000 = 0,0002 [1/degC] (or 0,02% or 200ppm)
I then insert 0,0002 as TC1 and the temperature behaviour works as expected.
Of course, a temperature change of only 1 degree C results in almost 0 change, but that was only an example and my real simulations uses higher temperature differences.
Hopes this clarifies the behaviour.
Regards, Åsmund
Message 7 of 8
(5,350 Views)
Thank you. I was thinking in that direction, but wasn't sure I really appreciate your response to my inquiry. This is something in my opinion that Multisim should automatically calculate. I know NI is already aware of the situations with this, but I thought I would let my opinion be known.
Thanks again.
Have a Nice Day
Message 8 of 8
(5,325 Views)
