Multisim and Ultiboard
Starting With Blank 2K8RAM
Hey
I'm working on a small project were I'm using the 2K8RAM component as storage for a program.
The project is a small MCU/CPU, I'm using the 2k8Ram as a program storage.
My problem is that when I start the simulation the 2k8Ram starts with all addresses is in an unknown state, and this is causing some problem when I try to load my program.
I've solve this problem by programming a 8051 to set all addresses to 0 and then load  my program,
but this takes 1.5 minutest to clear and load a 24 instruction (4 commands) program...
I could use the  8051 to give out the commands, but I rather have it just load the program in ram and then "virtually" remove itself.
I'm wondering is there is an other component or an other way to load a program in to a blank memory?
The point of this project is just to learn how a simple 8bit CPU might be constructed.
If I give the instructions to the circuits it runs fine, but I takes a lot of time to give 6 instructions (with is actually just on command) manualy and that is preventing me from getting further in the design, because
1. if I do it manulay and there is a small error I have to stop the simulation, fix it and then "reprogram it"
2. I had to re-do a lot of things to try and "debug" the circuit while the error was actually the ram being in an "unknown state" (rooky mistake) .
Side note:
I'm doing this at home so there might be something that I'm missing/doing wrong and I don't know people that can help me.
I'll upload the circuit if it's needed, but I prefer not to because it's in a lot of small pieces right now.
No matter how clever and complete your research is, there is always someone who knows more.
(4,958 Views)
Seriously nobody know of anyother method of doing it?
the time went up to 5-6 minutes per runn just to clear and load the memory.
I've been forced to just clear 64 adresses just to get it down to 2 minutes.
I'm wondering if I'm not just use the 8051 as a storing medium since nobody in the forums I've asked can answer me ;__;
(4,879 Views)
