Multisim and Ultiboard
Simulation Timing?
Should be a simple solution, but it has been a few years since I have MultiSim-ed.  I want to dictate the speed in which the simulation runs.  Basically, in the simulation, it take about 2 mintues to simulate about 1 second of real life action that will occur (the "Trans: 1.000 s" at the bottom of the window).  I basically would like to change this to run about real time, and have found no documentation.  I have been wondering this since college!  So you gurus probably know, but please enlighten me!  I would also like to know of a good doc source so I can solve these sorts of problems on my own.
Thanks a bunch!
Colb
(5,019 Views)
It is not going to be possible to achieve real time simulation, since a lot of calculus and mathematics are going-on on the background. However, you can try to manipulate simulation speed by changing the timestep of the simulation. There are two places you can try:
Simulate >> Interactive Simulation Settings.. and check the section for timestep.
Simulate >> Digital Simulation Settings.
For technical documents about Multisim, check-out the new Technical Library:
http://zone.ni.com/devzone/cda/tut/p/id/5579
Nestor
(5,015 Views)
This worked great.  I actually got it to run pretty close to real time, although I might be losing some math processes.  Oh well, seems to sim correctly.
Thanks again.
(5,012 Views)
